arotenst2
Not able to accept solution or just to reply.
After a job change I had to create a new Xilinx account as I was not able to login and modify my previous login information. Not sure if this matters, but now I am not able to accept any solution, give kudos or just simply reply in Forum. The only available option is Sharing. I cannot  continue the conversations. Please help.
Thank you.
arotenst2
Thank you. This is not about disconnecting faster. It looks now Xilinx requires to sign in again from the same window. Weird requirement.
watari
Hi @arotenst2
Would you make sure login status ?
Recently Xilinx changes authorization system. Therefore login session seems to disconnect faster than before.
Best regards,
arotenst2
