nag.chil
PCIE KC705 xapp1052 Error in Link Width
Iam Implementing PCIe BMD design in KC705 using vivado. Following XAPP1052.
I have programmed FPGA Succesfully.
loaded xbmd linux driver also successfully.
Compiled xml file and got executable file.
But when i open ./xbmd_app it is showing some error and application is closing
Error is: Negotiated Link speed read not valid: Read LW = 0
Please see attached screen shot file for details
Please can anyone say what that error is and what is remedy ?
balkris
check this ARs
https://www.xilinx.com/support/answers/36593.html
This forum post may be helpful
https://forums.xilinx.com/t5/PCI-Express/XAPP1052-Win7-64-bit-BSOD-and-Ubuntu-11-10-32-bit-Error/td-p/216783
Thanks and Regards
Balkrishan
balkris
check this ARs
Thanks and Regards
Balkrishan
nag.chil
Tq balkris
2nd link helped me a lot,
Earlier i have changed ioctl to unlocked_ioctl but didn't changed the arguments.
Now after changing arguments it worked.
Thankyou once again,
Continue your best services.
RGDS,
CNR
