11-07-2016 02:05 AM
Hello i have been working on PCIe XBMD design..
After loading the module I have observed that Configuration space of FPGA shows pin A routed to 11
lspci in linux terminal shows pin A routed to 16.
Why can anybody can say the reason.....??
Which one is correct one...
11-28-2016 06:30 AM
Please refer to the below doc and follow the procedure and see if you see the same behaviour
https://www.xilinx.com/support/documentation/application_notes/xapp1052.pdf
BMD design drivers and application are tested on fedora 10.
Sethu
