Abdul6498
Please correct the errors and send your information again. We cannot fulfill your request as your account has failed export compliance verification.
I was trying to download Vivado. While filling out the form I have received the following message.
"Please correct the errors and send your information again. We cannot fulfill your request as your account has failed export compliance verification."
Please try to solve this issue immediately because I have a class today and I need this software.
anatoli
Hello @Abdul6498 , @Abdul98640 ,
Your first account (with your University email address) is now active.
However, for your second account, i've sent you an email, as there are some additional info required from your end.
So, you shouldn't have any issues in downloading Xilinx Software using your first account.
As a recommendation, since your profile was blocked in the first place, there is a chance that each time when you update your Xilinx.com profile in the future, it will get blocked once again. Therefore, please don’t update your profiles (unless it is needed to do so) once the profile is re-enabled.
If this happens for you again, please contact Xilinx Customer Support(websupport@xilinx.com) (see AR https://www.xilinx.com/support/answers/44043.html for more details) and we will unblock your profile again then.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
anatoli
Hello @Abdul6498 ,
Looks like your Xilinx.com profile is currently blocked and is being screened by our export compliance team and is placed on hold and that is the reason why you are currently unable to generate a license or download Vivado.
Therefore, please contact Xilinx Customer Support (websupport@xilinx.com) (see AR https://www.xilinx.com/support/answers/44043.html for more details) and they will work with Global Trade Compliance team (GTC) to get this checked and unblocked for you then.
Kind Regards,
Anatoli Curran,
Versal Blogs
Abdul6498
I have contacted Xilinx. But they didn't reply.
anatoli
Hello @Abdul6498 ,
I'm actually one of the guys who has access to this inbox, however i don't see any emails from you.
Can you please resend this one again, as we actually need an email received from an user (as a request), so that this can be forwarded to the Xilinx Export Compliance team and to get your account unblocked.
Kind Regards,
Anatoli Curran,
Versal Blogs
Abdul6498
Can you please check you email now.
anatoli
Hello @Abdul6498 ,
It is strange indeed, as i still can't see this in the queue.
Please forward that email to me directly, as i need to investigate why your email hasn't come to us.
My email is just my first name @xilinx.com
At the same time, i've requested to check and update your profile. I will update you once this is done.
Kind Regards,
Anatoli Curran,
Versal Blogs
Abdul6498
Can you please check your email now?
anatoli
@Abdul6498 ,
Nope, haven't received this as of yet.
Somehow your emails aren't getting delivered to us.
I've checked the Junk inbox, in case it may went there, but no, still haven't received this.
Anyhow, I will update you once your account is active.
Kind Regards,
Anatoli Curran,
Versal Blogs
Abdul6498
From other email address
anatoli
Hi again @Abdul6498 ,
I have now received this into my inbox as well as into websupport inbox. However, from a different email address, to what is in your Xilinx.com profile.
Perhaps there is an issue with your university email address?
Kind Regards,
Anatoli Curran,
Versal Blogs
Abdul6498
Abdul98640
@anatoli
This is my second account and I'm facing the same issue.
Abdul98640
@anatoli
Can you please solve this issue as you have got the email?
anatoli
Kind Regards,
Anatoli Curran,
Versal Blogs
