Please tell me about PLL of Spartan6
Please tell me about PLL of Spartan6.
When the state of the input clock of PLL changes, is the reset to PLL necessary?
When Low was fixed reset of PLL, the following results were provided.
Even if the state of the input clock of PLL changed as for the simulation result of ISE, LOCKED signal became H.
In addition, in the board evaluation, LOCKED signal became H even if the state of the input clock of PLL changed.
Hi @m.okada
If it resolved you quaries ,Please mark the Answer as "Accept as solution.
Sarada
 @m.okada,
Once after the reset sequence completed  the PLL will lock to provide the clean VCO frequency.
Please refer page 47 for PLL functions and reset sequence.
http://www.xilinx.com/support/documentation/user_guides/ug386.pdf
Sarada
Thank you for an answer.
Is it correct on page 47?
There was not information of the reset.
Hi @m.okada
Please check the Page 47 to 54 for the PLL function and reset sequence.
Sarada
I do not use GTP, is page 47 to 54 right?
My questions are as follows.
When the state of the input clock changed, is the reset of PLL necessary?
(as for the simulation of ISE, reset was unnecessary.)
Hi @m.okada.
Yes it is needed to reset the PLL if the input frequency to it changes.
Sarada
Thank you.
Hi @m.okada
Sarada
