12-21-2016 05:02 PM
I have generated post implementation netlist by using below commands, but I am confused regarding how to map RTL I/Os to netlist I/Os with the same module, so Test bench can drive the I/Os In netlist file, I see there is wrapper around what is supposed to be the top (top in RTL) and again there is one parent which have only two input sysclk and sysrst.
1. write_sdf -mode timesim C:/AtomicSub_ip.sdf
2. write_verilog -mode timesim -sdf_anno true -sdf_file C:/AtomicSub_ip.sdf C:/AtomicSub_ip.v
Urvish
12-21-2016 05:14 PM - edited 12-21-2016 05:14 PM
@urvish_panchal89 if you did things properly, the RTL top level & gate-level top level ports should be identical.
I am afraid this sentence is not very clear to me. What exactly is the problem?
12-21-2016 05:32 PM
Hi Muzzafer,
# I see there is wrapper around what is supposed to be the top (top in RTL) and again there is one parent which have only two input sysclk and sysrst.
I have attached 3 files. If you look at it, you will understand.
AtomicSub_ip_gatelevel.v :- Gate-level file.
AtomicSub_ip_dut_1.v :- RTL top level module source file
AtomicSub_ip_src_Atomic_Subsystem_2.v :- RTL source file
#if you did things properly, the RTL top level & gate-level top level ports should be identical.
Can you elaborate since ports are not identical.
Urvish
12-21-2016 06:09 PM
Can you share a small testcase explaining the issue?
12-21-2016 06:32 PM
@urvish_panchal89 there are no files attached to this thread, so try posting again with attachments.
If you have only clock & rst going into the chip, it means that the implementation has removed all of your logic which means your logic wasn't showing input pin to output pin connectivity. You need to test your design more thoroughly for pin to pin functionality.
12-22-2016 10:22 AM
