Problem with ch7301c
Can any body help me please:
I am trying to run a crt monitor in xc5vlx110t but got stuck with ch7301c . Simulation of this code is working as specified in datasheet and ch7301c is also sending acknowledge bit but code is not working as expected......
Not able to figure out what is the problem.
module main(
input USER_CLK,
output SCL_o,
inout SDA_main,
output reset,
output reg [7:0] led);
wire sda_o;
wire sda_i;
reg bi;
reg [10:0] count_main;
reg [10:0] count;
reg SDA;
reg [10:0] count_bit;
reg [10:0] scl_flag;
reg SCL_R;
reg SCL;
reg [10:0] count_2;
initial
begin
SCL<=1'b1;
count_bit<=11'b00000000000;
SDA<=1'b1;
scl_flag<=11'b00000000000;
SCL_R<=1'b1;
bi<=1;
count_main<=11'b00000000000;
count<=11'b00000000000;
count_2<=11'b00000000000;
led<=8'hff;
end
assign sda_i=SDA_main;
assign SDA_main=(bi)?sda_o:1'bz;
assign sda_o=SDA;
assign SCL_o=SCL;
assign reset=1'b1;
always @(posedge USER_CLK)
begin
    if(scl_flag==0||scl_flag==1)
    begin
            if(count_2==49)
            count<=0;
            else
            count_2<=count_2+1;
            if(count_2==0||count_2==25)
            begin
            if(SCL_R==1'b1)
            begin
                SCL_R<=1'b0;
                scl_flag<=scl_flag+1;
            end
            else
            begin
            SCL_R<=1'b1;
            end
           end
    end
    else if(scl_flag>=2)
    begin
       if(count==99)
        count<=0;
        else
        count<=count+1;
        if(count_2==49)
        count_2<=0;
        else
        count_2<=count_2+1;
        begin
            if(SCL_R==1'b1)
            SCL_R<=1'b0;
            else
            SCL_R<=1'b1;
        end
        if(count==0||count==50)
        begin
            if(SCL==1'b1)
            SCL<=1'b0;
            else
            SCL<=1'b1;
        end
end
end
always @(negedge SCL_R)
begin
case(count_bit)
10:SDA<=0;
11:SDA<=1;
13:SDA<=1;
15:SDA<=1;
17:SDA<=0;
19:SDA<=1;
21:SDA<=1;
23:SDA<=0;
25:SDA<=0;
27:;
28:;
29:SDA<=1;
31:SDA<=0;
33:SDA<=1;
35:SDA<=0;
37:SDA<=0;
39:SDA<=0;
41:SDA<=0;
43:SDA<=1;
45:;
46:;
47:SDA<=0;
49:SDA<=0;
51:SDA<=0;
53:SDA<=0;
55:SDA<=1;
57:SDA<=1;
59:SDA<=0;
61:SDA<=1;
63:;
64:;
65:SDA<=0;
66:SDA<=1;
70:SDA<=0;
71:SDA<=1;
73:SDA<=1;
75:SDA<=1;
77:SDA<=0;
79:SDA<=1;
81:SDA<=1;
83:SDA<=0;
85:SDA<=1;
87:;
89:SDA<=1;
91:SDA<=1;
93:SDA<=1;
95:SDA<=1;
97:SDA<=1;
99:SDA<=1;
101:SDA<=1;
103:SDA<=1;
105:bi<=0;
107:;
108:led[7]<=sda_i;
110:led[6]<=sda_i;
112:led[5]<=sda_i;
114:led[4]<=sda_i;
116:led[3]<=sda_i;
118:led[2]<=sda_i;
120:led[1]<=sda_i;
122:led[0]<=sda_i;
123:begin bi<=1; SDA<=0; end
124:SDA<=1;
endcase
if(count_bit<=125)
count_bit=count_bit+1;
end
endmodule
Re: Problem with ch7301c
I am first writing to 21 register then again reading from it
EXACTLY how is it not as expected?
Posting simulation and ChipScope waveforms might help debugging.
However, I would advise you to take a course module on FSM design. I am no Verilog expert, but your 'always @(negedge SCL_R)' process is a total abomination!
"If it don't work in simulation, it won't work on the board."
Device is sending me acknowledge for 21f but not for 33f after writing 21f as 00001101. If i read this register it gives me 00000111;sim.png
simulation is as specified in datasheet
Plese help me I am stuck with this thing for 10 days
Instructor
Instructor
I do not use the Chrontel CH7301C.  Having said that, here are some suggestions:
  • If you are using a Xilinx FPGA development board, examine the reference designs for the board for example code and practices.
  • Solicit support from the Chrontel website and/or user forum.
  • Have you downloaded and read the Chrontel register apnote AN-41?
From the New Users Forum README thread:
Chrontel CH7301C VGA/DVI video encoder datasheet registers apnote (plus many forum threads discussing this device)
-- Bob Elkind
SIGNATURE:
Summary:
Yes, My protocol exactly as specified in an41
Historian
Historian
[snip horrific code]
If your simulation DOES NOT include a bus-functional model of the ch7301c, then your simulation is not complete and cannot be said to be "working as specified in datasheet."
