prakashdrj
RATE change in GTX zynq-706
How to change RATE in GTX zynq-706, UG467 V1.11.1 described RATE change sequence for GTH Only via [TX/RX]RATE[2:0] signals? Is there any sequence for GTX?
Tags (2)
vuppala
Hi @prakashdrj
Compare the generated _gt.v/.vhd files to find the attribute differences.
Vinay
vuppala
Hi @prakashdrj
You can achieve this using DRP functionality.
Check this forums thread: https://forums.xilinx.com/t5/7-Series-FPGAs/Questions-about-Kintex-7-GTX-drp-usage/td-p/305633
Vinay
prakashdrj
Ya, DRP is there and I can use. but I want to know If I can use [TX/RX]RATE signal like PCIe have.
any way DRP is last option!
vuppala
Hi @prakashdrj
You can achieve this by changing TXRATE.
Check the page no. 151 in the following user guide: http://www.xilinx.com/support/documentation/user_guides/ug476_7Series_Transceivers.pdf
Vinay
prakashdrj
Hello @vuppala,
So just by changing RATE signal I can? Doesn't It have sequence like GTH?
Prakash
prakashdrj
How can I see all attributes generated/set by wizard? In context of GTX?
saradapr
Hi @prakashdrj,
Hope you checked usage of TXRATE/RXRATE ports?
Generate the GT wizard core for the initial line rate Generate the GT wizard core for the modifying line rate. Compare the core files for both and note the attributes which differ.Then modify the required attributes for new rate change.
Give necessary resets, after changing these attributes as given in GT user guide.
Sarada
prakashdrj
Ok! Understood. Is there any way to find out which attributes are differed? Or shall I have to check all files?
vuppala
Hi @prakashdrj
Vinay
prakashdrj
Hello @vuppala,
I have doubt, should I start DRP operation after gtx_[tx/rx]resetdone_out completes or it is independent of gtx block? suppose after Power-On-Reset, I do DRP for [TX/RX]_DATA_WIDTH but actual gtx_[tx/rx]resetdone_out will be asserted long time after DRP completes? Is it affect DRP Operation?
In short DRP should be after gtx_[tx/rx]resetdone_out or irrespective of gtx_[tx/rx]resetdone_out?
Prakash
