12-04-2018 01:02 PM
here it is again in zip type... it complains about "does not match its file extension and has been removed"
I have try the file extension, doc, zip , ila and none of them is accepted
12-05-2018 07:05 AM
Here is the .ila file.
Finally able to attach the waveform file that display the fast ddr3 controller interface timing.
12-04-2018 04:12 PM
Try to create a zip file which contains your file.
I had a similar problem with a large text output file. The zip file was smaller than the original, and was successfully accepted.
Luck,
Peimann
12-04-2018 04:54 PM
This is a small (131k) ILA file, but I change the file extension from ila to txt, doc, zip and still complain.
12-04-2018 05:31 PM
Instead of changing the file extension (as in renaming file)... Actually 'zip' (compress) the file, which automatically puts the 'zip' file extension.
Hope that helps
12-05-2018 06:17 AM
Good Morning @tchin123,
You will have to actually zip the file to upload it.
Simply renaming is not adequate, as you found out.
Good Luck!
peimann
12-05-2018 07:05 AM
