Real Radix
When I am selecting radix setting to "Real" in ILA waveform window of Hardware Manager, the setting resets every time ILA is triggered. I am able to do the change in Vivado 2015.x but not in 2016.x. Can you please help me?
Is it a bug to be reported? Is there any workaround for this?
Varma
Hi@Varma,
This is a known issue and we are also having a CR-963037 on this issue. This has been discussed earlier.
Please refer the below forum link.
https://forums.xilinx.com/t5/Design-Tools-Others/Real-Radix-Setting-reset-in-Vivado-2016-1-2016-2-2016-3-Hardware/td-p/730507
Asit
Hi@Varma,
Asit
