ks14ch93
Reducing latency
Hello everyone, I need your advise about the following nested loop.
legalizeEdge_label1: while (n > 0) {
legalizeEdge_label4: for (int i = 0; i < 6; i++) {
	if (((Edges[i].mA != 0 && Edges[i].mB != 0)|| (Edges[i].mB != 0 && Edges[i].mC != 0)|| (Edges[i].mC != 0 && Edges[i].mA != 0))&& done == 0) {
legalizeEdge_label5: for (int i = 0; i < MAX_NO_TRIANGLES; i++) {
        if ((Triangles[i].mA == v2 || Triangles[i].mB == v2 || Triangles[i].mC ==v2) && done < 2) {
        if (Triangles[i].mA == v3 || Triangles[i].mB == v3|| Triangles[i].mC == v3) {
        if (Triangles[i].mA == v1 || Triangles[i].mB == v1|| Triangles[i].mC == v1) {
This nested loop has the following analysis window.
Analysis window
Is there any way (directives or change the code) to reduce latency cycles....??
I already convert all the float variables into fixed point and I reduce latency a lot of cycles  but I need to do something more.
Thanks in advance...!!!!
u4223374
Advisor
Advisor
Is the "label4" loop pipelined?
It looks like the main problem is that it's trying to do lots of reads from Edges simultaneously. What is "Edges"? An array of structs? If so, using DATAPACK on it might do what you need.
ks14ch93
No pipeline for any loop. I try a lot of directives before but no one effects to the latency.
"Edges" is array of class with 3 integers members.
u4223374
Advisor
Advisor
Try pipelining both the "label4" and "label5" loops. At least then HLS will give you more information about which parts are limiting your performance - almost always either dependencies or limited ports.
ks14ch93
Vivado_hls don't give me the option of DATAPACK for an array of struct. What to do about that..??
The only way that I have the option to use DATAPACK is only for the member variables of the struct.
