Visitor vegovin
Require minimum clock to Q delay for SPARTAN-3AN
I am using SPARTAN-3AN device. In order to calculate the hold margin I need to have the minimum clock to Q delay. At the monment datsheet only provide maximun clock to Q delay. Please let me know how to consider this Tcq delay(min) for calculating the hold margin.
Venkatesh
Instructor
Instructor
Re: Require minimum clock to Q delay for SPARTAN-3AN
When you built your design, the static timing report will show you min and max timing in the "datasheet" section at the end.  Note that you should select a verbose report and enable the data sheet section in the post P&R static timing generation options.
-- Gabor
Historian
Historian
@vegovin wrote:
Venkatesh
Hold time on input pins? Or hold time inside the FPGA fabric?
Visitor vegovin
You can give me hold margin with respect to input pin. I would be good if you can share the data for the IC fabric also.
Thanks and regards,
Venkatesh
Historian
Historian
@vegovin wrote:
The Spartan 3AN FPGA Family Data Sheet (DS557) details setup and hold time for various combinations of IFD_DELAY_VALUE and specific parts. Did you read that document?
That same document -- WHICH YOU SHOULD HAVE READ -- has those details, too. Pro Tip: in the FPGA fabric, the slices are designed so that the flops have a zero hold time requirement.
