Restoring the GOLDEN FPGA Configuration for Virtex II Pro
Hi, i need to restore the GOLDEN FPGA Configuration for Virtex II Pro, and y need the file XUP_V2Pro_BIST.zip, where I can get it?
Re: Restoring the GOLDEN FPGA Configuration for Virtex II Pro
@jhabril
Please check below link uilt-in-self-test (BIST) section and download the zip file
http://www.xilinx.com/univ/xupv2p.html
Here is the UG for it
http://www.xilinx.com/univ/XUPV2P/Documentation/ug069.pdf
Hope this helps
-Vanitha
I can't find  the file XUP_V2Pro_BIST.mcs, is it in the .zip file?
@jhabril Its not available there in the zip file. You have to create the .mcs using bit files. I have attached .mcs which can be used (i have created this one from the rev_a and rev_b bitstream downloaded from the zip) Hope .mcs attached would work.
-Pratham
@No, it didn't work, i tried to generate the file, but i getting this (i'm using ISE 10.1 and Virtex-II  Pro, what should I use?):
Xilinx Platform Studio
Xilinx EDK 10.1 Build EDK_K.15
Copyright (c) 1995-2008 Xilinx, Inc. All rights reserved.
XPS% Evaluating file C:\Xilinx\proyectos\restore\system.setprop.tcl
WARNING:MDT - Option "CORE_STATE" in
C:\Xilinx\proyectos\bist_rev_1_6\pcores\opb_ac97_v2_00_a\data\opb_ac97_v2_1_0
.mpd line 18 is deprecated. Please use Option ARCH_SUPPORT_MAP instead.
ERROR:MDT - IPNAME:plb_ddr INSTANCE:ddr_sdram -
C:\Xilinx\proyectos\bist_rev_1_6\system.mhs line 180 - PARAMETER C_DDR_TREFC
not found in mpd.
ERROR:MDT -
C:\Xilinx\proyectos\bist_rev_1_6\pcores\hw_bist_v1_01_d\data\hw_bist_v2_1_0.m
pd line 52 Invalid Signal name DIR=OUT
ERROR:MDT - Errors while parsing MPD file
pd
ERROR:MDT - C:\Xilinx\proyectos\bist_rev_1_6\system.mss line 114 - Can not find
MLD for the library xilnet 1.00.a
INFO:MDT - Directories Searched :
- C:\Xilinx\proyectos\bist_rev_1_6\sw_services/xilnet_v1_00_a/data
- C:\Xilinx\10.1\EDK\sw\ThirdParty\sw_services/xilnet_v1_00_a/data
- C:\Xilinx\10.1\EDK\sw\XilinxProcessorIPLib\sw_services/xilnet_v1_00_a/data
- C:\Xilinx\10.1\EDK\sw\lib\sw_services/xilnet_v1_00_a/data
ERROR:MDT - Can not find MLD for the library xilnet 1.00.a
ERROR:MDT - while loading XMP file
Process "Updating XPS project device settings" failed
@jhabril What is the error message you got during flash programming?
-Pratham
@pratham I got it when ISE generateserror_mcs.png the mcs file,
@jhabril You dont have to generate .mcs file. I have sent the .mcs file, can you program the flash using ise imapct tool? If you need any help programming flash let us know. If flash programming is failing please post the screenshot/log from the imapct here
-Pratham
@pratham Done, but the golden config doesn't work, no initial test, no video sound or anything, what can I do?
