RoHs & REACH & China RoHs declaration request
Customer Part No. Manufacturer Name Manufacturer Part No. Part Description
A9PLDXA6SLX75-2R XILINX XA6SLX75-2FGG484Q PLD XA6SLX75-2
IM350-947-707 XILINX XC6SLX4-2CSG225C SPARTAN-6  BGA  XC6SLX4
ILIS-253032-R XILINX XC3S1500-4FGG676C IC SPARTAN-3 FPGA 1.5M 676-FBGA
ILIS-252806-R XILINX XCF08PVOG48C IC PROM SRL 1.8V 8M GATE 48TSOP
ILIS-252689-R XILINX XC9536XL-10VQG44C IC CPLD .8K 36MCELL 44-VQFP
PF124557H-R XILINX XC3S50AN-4TQG144C IC FPGAFLASH XC3S50AN-4TQG144C TQFP ROHS
V3-226036-R      XILINX                              XCR3256XL-12PQG208I       IC CPLD 3.3V 6K GATE 256 MACROCELL PFQP
V3-225935-R      XILINX                              XC3SD1800A-4CSG484I             SPARTAN-3A DSP FPGA 309 USER IO 484-PIN
P2SBGAXC6SLX-R XILINX XC6SLX150-3FGG900C IC FPGA 576 I/O 900FBGA
Please check whether the below websites information is helpful for your requirement.
http://www.xilinx.com/support/quality/pb-free-rohs-compliant.html
http://www.xilinx.com/support/documentation/quality/certificates/china-rohs-disclosure-tables.pdf
If you do not get required information from the above sites I think you need to create Service Request through http://www.xilinx.com/support/service-portal.html or contact FAE/DFAE.
Please help to advise which are the part for 5 of 6 and 6 of 6 RoHs.
Also customer side require RoHs Exemptions information for each part. Please advise where we can get the information.
