Visitor ijdalal
[SDAccel 2015.3]Error: [Common 17-69] Command failed: File '../test-cl.c' does not exist.
I started playing with SDAccel tool today. I am trying out the matrix_multiply_c_kernel (given in SDAccel documentation lounge) and gave the following command:
sdaccel example_alphadata.tcl
Here's the log of output I get:
****** sdaccel v2015.3 (64-bit)
**** SW Build 1401868 on Wed Nov 4 16:34:39 MST 2015
** Copyright 1986-2015 Xilinx, Inc. All Rights Reserved.
source path/example_alphadata.tcl -notrace
INFO: [SDAccel 60-409] Creating solution...
INFO: [SDAccel 60-408] Solution Name: 'example_alpha'
INFO: [SDAccel 60-407] Solution Dir: '.'
ERROR: [Common 17-69] Command failed: File 'path/test-cl.c' does not exist
INFO: [Common 17-206] Exiting sdaccel at Wed Dec 16 17:04:21 2015...
test-cl.c is in same directory as the tcl script for which command is run.
Re: [SDAccel 2015.3]Error: [Common 17-69] Command failed: File '../test-cl.c' does not exist.
Hi ijdalal,
I will send you my contact via PM. Let us resovle your SDAccel issues offline.
Cheers,
Jim
