leonardo.solis
SDAccel error running "sdaccel pipelined_hw_emulation.tcl"
I am trying the example code "as is". Particularly "sdaccel pipelined_hw_emulation.tcl", compiles and generates the executables for host and kernel, but has errors during execution:
INFO: [SDAccel 60-348] Executing hardware emulation using software accelerators...
INFO: [SDAccel 60-280] Additional args : '-d acc -k test.xclbin'
INFO: [SDAccel 60-174] Running emulation command line: /home/lvs/SDAccel_examples/getting_started/cur_alpha_data/pipelined_solution/impl/sim/hw_em/pipelined_solution.exe -d acc -k test.xclbin
Input sequence1: TAGGCAAGACCACTTTAGCATGGTCTACAACGCCTAGACCTTTGGCAAAGCAGATCGGCCCGCCCATCACTAGTGGGACTATCC
Input sequence2: TAATGGGAACACCTGCTGCAATCGGATCGTTGCAGCGGTAATGTGTCGGTATATGCGAGTAGGGTAATCCAAACGTCCCATTGC
Platform = Xilinx
Device = fpga0
OpenCL Version = 1.0
Loading test.xclbin
binding stream socket: Permission denied
Platform = Xilinx
Device = fpga0
Loading test.xclbin
ERROR: [SDAccel 60-301] Run emulation failed
INFO: [SDAccel 60-349] Executing hardware emulation using software accelerators...COMPLETE
ERROR: [Common 17-39] 'run_emulation' failed due to earlier errors.
    while executing
"run_emulation -flow hardware -args "-d acc -k test.xclbin""
    (file "pipelined_hw_emulation.tcl" line 36)
INFO: [Common 17-206] Exiting sdaccel at Wed Dec  2 10:47:24 2015...
What does "binding stream socket: permission denied" mean?
So I tried also running as root:
Platform = Xilinx
Device = fpga0
Loading test.xclbin
but the execution is stuck right there (loading...) :(
Thank you very much for your suggestions.
Best,
L30nardo SV
pvenugo
Please refer to https://forums.xilinx.com/t5/Welcome-Join/Error-running-SDAccel-for-hardware-emulation/td-p/668691
This seems to be duplicate post.
Praveen
