SDK Build Error
while building sdk code i am getting foolowing erros
make: *** [ppc440_0/lib/libxil.a] Error 2
make: *** [src/main.o] Error 1
Please suggest me solutions
Re: SDK Build Error
check this ARs
http://www.xilinx.com/support/answers/57113.html
Thanks and Regards
Balkrishan
Re: SDK Build Error
I already tried it but that solution is not working
thanks
Re: SDK Build Error
Hi @dhananjay201190
Which version of SDK you are using?
SDK13.4?
Where is this SDK project located? Is it on your local drive or remote drive? Can you show me the path directory of the project?
For example,  C drive C:\Xilinx_cases\SDK_Workspace etc.
Sarada.
Re: SDK Build Error
SDK project is loacated in local drive only. path for it is PCIe_8Lane_ddc\ISE\PCIE_CTRL_PROC\SDK\SDK_Workspace_35 ,where in ISE folder vhd code is there. Also when i clean project project include folder from workspace is removed which has all .h files
