SDK2014.4 debug zedboard linux application
currently, I use SDK 2014.4 debug zedboard linux application.I followed the instruction http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/SDK_Doc/tasks/sdk_t_linux_application_debugging_system_debugger.htm.First, zedboard boot mode was SD boot.Then I have set ifconfig eth0 (192.168.1.10)But I have SDK verison 2014,4. In SDK XMD console when I use command "ping 192.168.1.10(I have already set ARM and PC ip address)", SDK can receive complete package message without error and lost.
But when I set debug configuration follow the instruction and debug,SDK report error message "(tcp:192.168.1.10:1534 disconnect )target does not provide processes sevice ".Can anyone help me?
