SDSOC platform creation and interrupt
Hello, I have been trying to do some minor modifications to the sdsoc at the zc702_led platform as in the attached png. Basically I connect one extra interrupt line to the xlconcat module and then try to regenerate the pfm for the platform with the corresponding tcl script. I always get errors like ERROR: pfm_irq - port 'In1' is not the least significant available port on instance 'xlconcat' However I am using In0 for my extra interrupt line so In1 is the "least significant available port" and the pfm is modified so it does not check In0 that is now is used by the other interrupt line. What could I be doing wrong, here please ?
OK, I figured it out.
I have to remove In1 in xlconcat so there are no ports disconnected and modified the tcl to start from In1.
Then platform generation works.
