barak_obama1
STM64(OC-192) implementation with kintex-7 transceivers using SFP+ without CDR
Hi all,
I received a note from Xilinx that if we want to implement STM64 (OC-192) with Kintex-7 transceivers using SFP+ to meet the STM64 jitter standard we should use SFP+ with CDR. But i ask this problem from producers and they answered me that STM64 jitter standard met by kintex7 and SFP+ wo CDR ( wo retimed).
I think the CDR of kintex -7 if enough.
please help me if I should pay more for CDR.
Bests
Jack
gnarahar
@barak_obama1 You asked this query here https://forums.xilinx.com/t5/7-Series-FPGAs/STM64-OC-192-implementation-with-kintex7-transceiver-using-SFP/m-p/735008
Please avoid duplicate posts.
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
balkris
check this link
https://www.xilinx.com/support/documentation/white_papers/wp427-7series-optical-primer.pdf
Thanks and Regards
Balkrishan
