Secure solution to web interface.
I'm following xapp1026 for web server code. I'm trying to add secure layer to it. using https (TLS v1.2). which library I can go with.
or is there any support from xilinx?
Please reply any suggestion. thanks in advance.
I am not sure if you are using provided code with XAPP1026. You can find here
XAPP1026 - LightWeight IP (lwIP) Application Examples v5.1 Application Note ( ver5.1, 1782 KB ) [PDF]
Design File(s)
Thanks and Regards
Balkrishan
