Observer akiaji
Service portal login problem
I'm trying to connect service portal to request "rehost assistance" written here(https://forums.xilinx.com/t5/Installation-and-Licensing/Error-maximum-number-of-allowed-license-key-regeneration/td-p/733064).
However, I got an error "invalid username/password specified.(SBL-UIF-00271)".
I tried to login after cleaning my browser chache and filling all of my profile (except Address 2 because it's not have to be filled) based on below but I got same result.
https://forums.xilinx.com/t5/General-Technical-Discussion/Service-Portal-Login-Problem/m-p/639867#M34736
https://forums.xilinx.com/t5/Welcome-Join/Facing-Portal-Login-Issue/td-p/928499
How can I login to the portal?
Please help to solve this problem.
akiaji
Re: Service portal login problem
Hello @akiaji ,
Your issue should now be resolved. Please try once again and let me know if you are still unable to log in.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hello @akiaji ,
Kind Regards,
Anatoli Curran,
Observer akiaji
Thank you for your reply @anatoli.
I can login to Service Portal now and I've submit SR.
I wait some responses now.
I appriciate you.
Kind Regards,
akiaji
