Visitor dwilens
Simulation GUI displaying incorrect data
The simulator displays underscores in the value column - this is obviously a bug.
row_in_counter counts a binary one on each clock. It appears to counts by 8 because you can see the lower 3 bits are considered to be zero and these bits are missing from the value column.
row_in_counter_test goes high only when row_in_counter is equal to 3. Somewhere inside the simulator, row_in_counter is correctly counting by one because you can see row_in_counter_test go high where the 3 should be!
Vivado Simulator 2015.3 on Windows 7
Re: Simulation GUI displaying incorrect data
Hi @dwilens
If your query is addressed, close the thread by marking the answer.
Deepika.
Hi @dwilens,
Can you try to relaunch simulation and check:
Nupur
Visitor dwilens
I have relaunched many times.
Visitor dwilens
I killed Vivado completely and resimulated; but got the same thing. You can download the entire project here:
https://mega.nz/#!NxMWlL5a!boRbeBZH602KtKzqYxc_QHV2LIszCxFmxv2U7Tw8Row
Click on download in your browser. You can see row_in_counter start to mess up at 77,827,080 nsec.
There is no mention of this obvious bug in the release notes, so I suspect Xilinx has no knowlege of it.
Hi @dwilens
Can you share the test case?
Deepika.
Visitor dwilens
How do I share it? It is 450 MBytes and the upload limit is 20.
Hi @dwilens
I just sent you ezmove package to upload the design.
Deepika.
Visitor dwilens
Sent it. Thanks for taking as look!
Hi @dwilens
I have filed CR 948762 and addressed this issue to factory.
Deepika.
Visitor dwilens
Thanks!!
How can I keep updated? Like if they come out with a fix in a future version?
Hi @dwilens
You can post here if you want update on the CR, we can check and let you know.
I will post here back once the CR is fixed.
Deepika.
Hi @dwilens
Deepika.
