Simulation error vivado HLS IP creating
Hi I have written this simple code to create an IP in HLS for my vivado design
#include"ap_int.h"
int transform(ap_int<3> input, int * output)
	int s ;
	s=input-1;
	*output=s;
return 0;
in which both input and output are axi stream interface, axis
I created this test bench
int transform( ap_int<3>, int * );
int main(void){
int i;
int y;
int x;
for (i=0; i<100;i++)
transform(x,&y);
return 0;
 and run simulation
and I receive this msg
@E [SIM-317] C++ compile error.
@E [SIM-321] EXE file generate failed.
@E [SIM-331] Aborting co-simulation: C simulation failed, compilation errors.
@E [SIM-4] *** C/RTL co-simulation finished: FAIL ***
command 'ap_source' returned error code
    while executing
"source C:/Users/DELL/workspace/project0/solution1/cosim.tcl"
    invoked from within
"hls::main C:/Users/DELL/workspace/project0/solution1/cosim.tcl"
    ("uplevel" body line 1)
    invoked from within
"uplevel 1 hls::main {*}$args"
    (procedure "hls_proc" line 5)
    invoked from within
"hls_proc $argv"
first where is C/simulation I just found verilog and vhdl, using vivado HLS 2015.1
second what is not working when I run the simulation
thank you
Teacher xilinxacct
Re: Simulation error vivado HLS IP creating
Teacher xilinxacct
@riwa
Running this on a newer version seems to work... I do note that 'x' is never initialized. I don't know if older versions are more suspectible to that.
Hope that helps
If so, please mark as solution accepted to close this issue. Kudos also welcomed.
