naralaraghu
Simulation library
I have a block design in vivado 2014.4, how can i generate simulation files for QuestSim
anusheel
Refer Chapter 8 from below link:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/ug900-vivado-logic-simulation.pdf
Anusheel
Helpful answer -> Give Kudos
aher
hi,
you can use tcl command
compile_simlib -simulator questa
to compile simulation libraries.
thanks,
Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in left) to a post which you think is helpful and reply oriented.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
vijayak
Hi @naralaraghu ,
Check this video for a quick demonstration
http://www.xilinx.com/training/vivado/simulating-with-modelsim-in-vivado.htm
Thanks,Vijay
vijayak
Hi @naralaraghu ,
Did that helped? If yes, plese mark the post that helped you as a solution.
Thanks,Vijay
