sushmahuddar
Simulation of Zynq Base TRD 2014.4
Hi ,
I am trying to simulate  Zynq Base TRD 2014.4 using Vivado 2014.4. When I run behavioral simulation, I get the following error
[USF-XSim 62] 'compile' step failed with error(s). Please check the Tcl console output or '' file for more information.
I opened the compile log & found the following errors
ERROR: [VRFC 10-91] oserdes2 is not declared [D:/sushma_huddar/TRD_1/pcie_trd/hardware/vivado/runs/z7_pcie_trd_2014.4.srcs/sources_1/ipshared/logicbricks.com/logicvc_v4_1/c764b255/hdl/src/vhdl/ser7to1_s6.vhd:12]
ERROR: [VRFC 10-1504] unit rtl ignored due to previous errors [D:/sushma_huddar/TRD_1/pcie_trd/hardware/vivado/runs/z7_pcie_trd_2014.4.srcs/sources_1/ipshared/logicbricks.com/logicvc_v4_1/c764b255/hdl/src/vhdl/ser7to1_s6.vhd:12]
The file "ser7to1_s6.vhd" is encrypted.
How do I get the simulations running???
Please help.
Thanks in advance
Sushma Huddar
pvenugo
Hi Sushma,
Do you still see this error on simulation?
Praveen
sushmahuddar
Hi Praveen,
I am unable to carry out simulation due these errors
Sushma Huddar
