jacob.varghese
Source not found in SDk
I am facing an issue when i try to debug a simple hello world project in SDK.I have attached my .bit file and .Xml file
Processor : Microblaze
Board : KC705
siktap
Can you see if this helps?
http://www.xilinx.com/support/answers/35996.html
Sikta
jacob.varghese
Hello Sikta,
Thanks for Replying..
I am using xilinx SDK 14.7 and I checked  GDB timeout settings Window > Preferences > C/C++ > Debug > GDB MI. tting, but GDB MI option was not there, So I changed XMD startup option, but still the error remains.
Thanks and Regards
Jacob
achutha
@jacob.varghese
Check if the steps shared by debugasm user in this post helps.
-Achutha
jacob.varghese
Hey,
I went through the thread,
I downloaded bitstream using impact.
 start debug ,where its showing same problem.
 send "rst" command in XMD console by specifying the processor
  --> rst  -mb
but it is coming as,
    Usage:  rst [-processor | -slcr | -debug_sys | -srst]
----> rst - mb
wrong # args: should be "rst ?reset_type?"
Can you tell me..where I am going wrong? I went through this link for command
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug1043-embedded-system-tools.pdf
jacob.varghese
I have used two project in xilinx SDK 14.7 one I  am using QSPI IP core and in  other one EMC IP core all other parameters are same. This issue is not coming for QSPI project, I am able to debug but the same is not happening with EMC IP core enabled.Anything to do with linker script or any memory mismatch occured.
Pleas reply I am struck with this issue for some times now.
jacob.varghese
<<<<<<<<<<<<<<< PROBLEM GOT RESOLVED>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
In linker script when I changed section to  memory  region mapping  from BPI flash to BRAM ,the issue got resolved.
Now I am getting error like bram memory overflowed. So, increasing BRAm memory will do the trick
