minyingtao2013
Spartan-6 GTP Data Error
Hi everyone, I'm using Spartan-6 GTP transmission 32bit data with 8B/10B, and using Optical fiber Outside FPGA, it's right when I download my code to the chip, but after I Pull out the Optical fiber and plug in Immediately with electricity(I call it Hot Plug), all data wrong Non-regularity, what can I do for this? Can I change the setting of aligement or 8B/10B or LOS state machine? Does the GTP have this function? I'm Very worried for this and I'm puzzled by this several months.
yenigal
It depends on the protocol you are using and if it has Hot Plug capability.
You can write a FSM to detect the cable pull it it is not included already and reset the core once it is detected to make the connection work normally.
Satish
minyingtao2013
Hi yenigal, thanks for your reply. I have used a FSM to detected if there is a comma "BC", and if no received "BC" in 32 consecutive 32bit-data("BC" is in bit7~bit0, every 32 32bit-data have one "BC"), I reset the GTP, but it always not detect "BC" and always in reset state, it just like this picture:
so I want to know:
How to detect if the cable is plug or unplug?
How to reset the GTP?
Which signal should I reset?
Does the "BC" is comma?
When I use 40bit data, it is not "BC" but "27C", but the K28.5 is also "27C", so I don't know if the comma "27C" is the K28.5 "27C"?
Should I change the setting of other ports or attributes to solve this question?
Or which protocol can support hot plug?
If you know this, please tell me, I will Very grateful to you in my heart.
minyingtao2013
Now the problem is data shifting,such as I send 0x2221201F, 0x26252423, 0x2A292827, if I don't pull out the optical, the 3 data I received all right, but after I pull out the optical and plug it immediately, I receive 0x0x21201F1E, 0x25242322, 0x29282726, it meanings that the high 8bit in data 0x26252423 shift to the low 8bit in data 0x2A292827, who can tell me why? What should I do to slove it?
Now the time is 02:07 AM in china, I will wait for the reply from everyone.
