imlibra
Still no response from Service Portal
I ordered accessories from Xilinx Online Store but didn’t received tracking number for days. I submitted a ticket on Service Portal but got no response. I called support, but once after I entered SR number, the phone call was ended.
SR number: 10519539
Order number: EC-0016532
anatoli
Hello @imlibra ,
Please note that there was a national time off in the USA and many people where out due to this.
However, i've just checked and i can see that the team has contacted you yesterday on this matter.
If that is the case, and if you don't have any further questions regarding this matter, please mark a response as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so that the topic can be completed then.
We appreciate your help.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
anatoli
Hello @imlibra ,
Kind Regards,
Anatoli Curran,
Versal Blogs
