Visitor cy-li
Stuck in Start Cross Boundary Optimization in VIVADO
Hi All,
I have a design using ram.
Synthesis get stuck in processing "Start Cross Boundary Optimization",
no matter Vivado 2015.2 or 2015.4.
It can finish synthesis when I don't use ram in design,
so I make a assumption that Vivado can work correctly.
Here is my runme.log.
Can anyone help me?
thanks.
Starting Synthesize : Time (s): cpu = 00:00:08 ; elapsed = 00:00:09 . Memory (MB): peak = 293.996 ; gain = 122.480
INFO: [Synth 8-638] synthesizing module 'FourBit_Trie' [C:/Users/lf2net624/Desktop/FourBit_Trie/FourBit_Trie.v:24]
INFO: [Synth 8-638] synthesizing module 'Stage0' [C:/Users/lf2net624/Desktop/FourBit_Trie/Stage0.v:11]
INFO: [Synth 8-256] done synthesizing module 'Stage0' (1#1) [C:/Users/lf2net624/Desktop/FourBit_Trie/Stage0.v:11]
INFO: [Synth 8-638] synthesizing module 'Stage1' [C:/Users/lf2net624/Desktop/FourBit_Trie/Stage1.v:13]
INFO: [Synth 8-638] synthesizing module 'rom1' [C:/Users/lf2net624/Desktop/FourBit_Trie/rom1.v:1]
Parameter ROM_WIDTH bound to: 12 - type: integer
Parameter ROM_ADDR_BITS bound to: 4 - type: integer
INFO: [Synth 8-3876] $readmem data file 'level01.txt' is read successfully [C:/Users/lf2net624/Desktop/FourBit_Trie/rom1.v:15]
INFO: [Synth 8-256] done synthesizing module 'rom1' (2#1) [C:/Users/lf2net624/Desktop/FourBit_Trie/rom1.v:1]
INFO: [Synth 8-256] done synthesizing module 'Stage1' (3#1) [C:/Users/lf2net624/Desktop/FourBit_Trie/Stage1.v:13]
INFO: [Synth 8-638] synthesizing module 'Stage2' [C:/Users/lf2net624/Desktop/FourBit_Trie/Stage2.v:13]
INFO: [Synth 8-638] synthesizing module 'rom2' [C:/Users/lf2net624/Desktop/FourBit_Trie/rom2.v:1]
Parameter ROM_WIDTH bound to: 16 - type: integer
Parameter ROM_ADDR_BITS bound to: 8 - type: integer
INFO: [Synth 8-3876] $readmem data file 'level02.txt' is read successfully [C:/Users/lf2net624/Desktop/FourBit_Trie/rom2.v:15]
INFO: [Synth 8-256] done synthesizing module 'rom2' (4#1) [C:/Users/lf2net624/Desktop/FourBit_Trie/rom2.v:1]
INFO: [Synth 8-256] done synthesizing module 'Stage2' (5#1) [C:/Users/lf2net624/Desktop/FourBit_Trie/Stage2.v:13]
INFO: [Synth 8-638] synthesizing module 'Stage3' [C:/Users/lf2net624/Desktop/FourBit_Trie/Stage3.v:13]
INFO: [Synth 8-638] synthesizing module 'rom3' [C:/Users/lf2net624/Desktop/FourBit_Trie/rom3.v:1]
Parameter ROM_WIDTH bound to: 19 - type: integer
Parameter ROM_ADDR_BITS bound to: 12 - type: integer
INFO: [Synth 8-3876] $readmem data file 'level03.txt' is read successfully [C:/Users/lf2net624/Desktop/FourBit_Trie/rom3.v:15]
INFO: [Synth 8-256] done synthesizing module 'rom3' (6#1) [C:/Users/lf2net624/Desktop/FourBit_Trie/rom3.v:1]
INFO: [Synth 8-256] done synthesizing module 'Stage3' (7#1) [C:/Users/lf2net624/Desktop/FourBit_Trie/Stage3.v:13]
INFO: [Synth 8-638] synthesizing module 'Stage4' [C:/Users/lf2net624/Desktop/FourBit_Trie/Stage4.v:13]
INFO: [Synth 8-638] synthesizing module 'rom4' [C:/Users/lf2net624/Desktop/FourBit_Trie/rom4.v:1]
Parameter ROM_WIDTH bound to: 21 - type: integer
Parameter ROM_ADDR_BITS bound to: 15 - type: integer
INFO: [Synth 8-3876] $readmem data file 'level04.txt' is read successfully [C:/Users/lf2net624/Desktop/FourBit_Trie/rom4.v:15]
INFO: [Synth 8-256] done synthesizing module 'rom4' (8#1) [C:/Users/lf2net624/Desktop/FourBit_Trie/rom4.v:1]
INFO: [Synth 8-256] done synthesizing module 'Stage4' (9#1) [C:/Users/lf2net624/Desktop/FourBit_Trie/Stage4.v:13]
INFO: [Synth 8-638] synthesizing module 'Stage5' [C:/Users/lf2net624/Desktop/FourBit_Trie/Stage5.v:13]
INFO: [Synth 8-638] synthesizing module 'rom5' [C:/Users/lf2net624/Desktop/FourBit_Trie/rom5.v:1]
Parameter ROM_WIDTH bound to: 22 - type: integer
Parameter ROM_ADDR_BITS bound to: 17 - type: integer
INFO: [Synth 8-3876] $readmem data file 'level05.txt' is read successfully [C:/Users/lf2net624/Desktop/FourBit_Trie/rom5.v:15]
INFO: [Synth 8-256] done synthesizing module 'rom5' (10#1) [C:/Users/lf2net624/Desktop/FourBit_Trie/rom5.v:1]
INFO: [Synth 8-256] done synthesizing module 'Stage5' (11#1) [C:/Users/lf2net624/Desktop/FourBit_Trie/Stage5.v:13]
INFO: [Synth 8-638] synthesizing module 'Stage6' [C:/Users/lf2net624/Desktop/FourBit_Trie/Stage6.v:13]
INFO: [Synth 8-638] synthesizing module 'rom6' [C:/Users/lf2net624/Desktop/FourBit_Trie/rom6.v:1]
Finished Synthesize : Time (s): cpu = 00:00:16 ; elapsed = 00:00:19 . Memory (MB): peak = 733.387 ; gain = 561.871
Finished Constraint Validation : Time (s): cpu = 00:00:18 ; elapsed = 00:00:21 . Memory (MB): peak = 733.387 ; gain = 561.871
Start Loading Part and Timing Information
Loading part: xc7v2000tfhg1761-2
INFO: [Device 21-403] Loading part xc7v2000tfhg1761-2
Finished Loading Part and Timing Information : Time (s): cpu = 00:00:18 ; elapsed = 00:00:21 . Memory (MB): peak = 733.387 ; gain = 561.871
INFO: [Synth 8-5544] ROM "rom_1" won't be mapped to Block RAM because address size (4) smaller than threshold (5)
Finished RTL Optimization Phase 2 : Time (s): cpu = 00:01:52 ; elapsed = 00:01:40 . Memory (MB): peak = 1919.875 ; gain = 1748.359
Report RTL Partitions:
| |RTL Partition |Replication |Instances |
No constraint files found.
Start RTL Component Statistics
Detailed RTL Component Info :
+---Registers :
32 Bit Registers := 7
23 Bit Registers := 1
22 Bit Registers := 1
21 Bit Registers := 1
19 Bit Registers := 1
18 Bit Registers := 1
16 Bit Registers := 1
12 Bit Registers := 1
8 Bit Registers := 9
1 Bit Registers := 7
+---ROMs :
ROMs := 7
+---Muxes :
17 Input 12 Bit Muxes := 1
2 Input 8 Bit Muxes := 8
Finished RTL Component Statistics
Start RTL Hierarchical Component Statistics
Hierarchical RTL Component report
Module Stage0
+---Registers :
32 Bit Registers := 1
Module rom1
+---Registers :
+---Muxes :
Module Stage1
+---Registers :
+---Muxes :
2 Input 8 Bit Muxes := 1
Module rom2
+---Registers :
+---ROMs :
ROMs := 1
Module Stage2
+---Registers :
+---Muxes :
Module rom3
+---Registers :
+---ROMs :
ROMs := 1
Module Stage3
+---Registers :
+---Muxes :
Module rom4
+---Registers :
+---ROMs :
ROMs := 1
Module Stage4
+---Registers :
+---Muxes :
Module rom5
+---Registers :
+---ROMs :
ROMs := 1
Module Stage5
+---Registers :
+---Muxes :
Module rom6
+---Registers :
+---ROMs :
ROMs := 1
Module Stage6
+---Registers :
+---Muxes :
Finished RTL Hierarchical Component Statistics
Start Part Resource Summary
Part Resources:
DSPs: 2160 (col length:60)
BRAMs: 2584 (col length: RAMB18 240 RAMB36 120)
Finished Part Resource Summary
Start Parallel Synthesis Optimization : Time (s): cpu = 00:01:53 ; elapsed = 00:01:41 . Memory (MB): peak = 1919.875 ; gain = 1748.359
Re: Stuck in Start Cross Boundary Optimization in VIVADO
@cy-li,
• The logic implemented in block RAM must satisfy the following criteria:
– All outputs are registered.
– The block contains only one level of Registers, which are Output Registers.
– All Output Registers have the same control signals.
– The Output Registers have a synchronous reset signal.
– The block does not contain multi-source situations or tristate buffers.
– Keep is not allowed on intermediate signals.
• Vivado attempts to map the designated logic onto block RAM during Low Level
Synthesis. When successful, Vivado issues a message.
Entity <logic_bram_1> mapped on BRAM.
• If any of the listed requirements is not satisfied, Vivado does not map the designated logic onto block RAM, and issues a warning.
Please check this w.r.t to your code and do the necessary modifications.
Also Check page number 100 in below Synthesis User guide:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug901-vivado-synthesis.pdf
Syed
@cy-li,
Syed
Hi @cy-li
In synthesis settings change the "flatten hierarchy" to NONE and see if that helps.
Thanks,Vijay
Hi @cy-li
Did you try the given options? Post the updates for futher help.
Thanks,Vijay
Visitor cy-li
Thank for your reply.
I have modified the block ram file to satisfy criteria that  @syedz provided.
I realize that it takes 16 hours to finish synthesis.
Thanks to@vijayak , your advice should also be helpful.
@cy-li,
Please close this thread by marking the post as "Accept as solution"  so that it will help for other users who could face the similar issue.
--Syed
