Suggest me books on microblaze using C programming
     I am new to microblaze environment and facing difficulties while programming the microblaze using C language. So, i want all of you to suggest some books or any detailed tutorial that help me to learn about microblaze.
Sherazi
Re: Suggest me books on microblaze using C programming
Remember that Microblaze is just another processor and almost all the code that you write in C, compiles in Microblaze as well. So any C programming book is enough for that.
Paul
If you are developing hardware for MicroBlaze using XPS then I suggest you refer to the following guide:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/edk_ctt.pdf
If you are using Vivado then refer to chapter 5 of:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_2/ug940-vivado-tutorial-embedded-design.pdf
Once you make the hardware in either XPS or Vivado, software (C) programming using SDK is very easy as there are number of APIs readily available.  For a list of MicroBlaze specific APIs, refer to page 11 of the following guide:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/oslib_rm.pdf
You can refer to this document which talks about the way xilinx drivers have been coded.
http://courses.cs.washington.edu/courses/cse467/05wi/pdfs/xilinx_drivers.pdf
--HS
