Synthesis stops at Low Level Synthesis
Hi guys,
My synthesis is taking more than 2 days, and still running.
The code should combine a input data with changing length to output data with constant length of 128 bits.
I do use an array of 2x128 bits and also a pointer to the array.
It stops at Low Level Synthesis:
Optimizing unit <compression_zeros_combine>...
Does someone have an idea about what's wrong?
Best regards
Hi @ivanov_marko,
Which version of Vivado are you using? Can you share the .log file?
Hi @florentw, I did make it synthesize but the function was changed so it was wrong. Now I developed it further: with 32 word width it works, but with 64/128 it doesn't. There is a file randomTo128_32_succeded.syr where it succeded but with more, it doesn't finish... The source file is randomTo128.source . You can change the N to the word width and k so that N=2^k.
