Anonymous
Not applicable
Synthesizing Error "Xst:899"
During synthesizing I got the following 2 errors.
ERROR:Xst:899 - "ASCII.v" line 96: The logic for <feed> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
ERROR:Xst:899 - "ASCII.v" line 97: The logic for <state> does not match a known FF or Latch template. The description style you are using to describe a register or latch is not supported in the current software release.
My program code is (full length program code is attached within the message)
always @(negedge feedback or negedge clkT) begin
        if(state===0)begin
            feed=1;              <-------------------------------------------------- error line 95
            state=1;             <-------------------------------------------------- error line 96
        end
        else begin
            feed=0;
            state=0;
        end
end
Please help, Urgent...
Re: Synthesizing Error "Xst:899"
Only one clock per process for synthesis. Even in Verilog!
"If it don't work in simulation, it won't work on the board."
Anonymous
Not applicable
Thanxx... done... :)
