System Generator CIC Filter
I am trying to use the CIC Compiler to create a decimate by 16 CIC Filter in System Generator.  When I build up a simple representation of the filter in an slx file I get an error message indicating the sample rate of the filter output is 1/4 that of the global sample rate as expected...how do I eliminate this issue?
Error message; Inconsistent sample times. Sample time (1) of signal driving input port 1 of 'diag_cic/Gateway Out1' differs from the expected sample time (4) at this input port.
