System Generator and MATLAB
Hello all
I need to ask you about the System Generator tool 2016.1, I have a MATLAB tool installed on my PC and it's 2016b version, but whenever i try to open the system generator tool and connect it with MATLAB it says " No versions of MATLAB were found on this PC " as shown in the picture below.
Doesn't system generator accept this version of MATLAB or what's the problem. If you know i would appreciate the help.
you should have compatible versions
https://www.xilinx.com/support/answers/55830.html
Thanks and Regards
Balkrishan
