danieledes92
System generator with virtex 6 and fmc 150
It is possibile to use fmc 150 with system generator and virtex 6 ml 605 board? I haven't a solution for this question.
Thank.
Tags (3)
yenigal
Yes it is possible to use Sytem generateor with ML605 and process the data from FMC150.
Satish
danieledes92
Hi yenigal,
thank you for your answer.
My work is a QPSK modulator and I wolud to see the output signal on the oscilloscope.
It is a month that I work on this project but i don't succeed to create a connection between fmc 150 and ML 605 to see the signal on the oscilloscope. I now see the QPSK signal with thank chipscope block.
How I can create a connection between ML 605 and fmc 150?
I attach my projecty in System generator.
Daniele.
danieledes92
I attach the file written in System Generator.
Best regards.
