01-08-2015 12:41 AM
[Drc 23-20] Rule violation (IOSTDTYPE-1) IOStandard Type - I/O port systemClockN is Single-Ended but has an IOStandard of LVDS_25 which can only support Differential
I am getting this error
I am using Znyq zc702 board. I am using system clock 200MHZ . It gives differential output. I am using the template which is present in Vivado 2014.2 for IBUFDS. IBUFGDS is not there i those templates. Please help me
01-08-2015 12:44 AM - edited 01-08-2015 12:50 AM
The following AR http://www.xilinx.com/support/answers/57109.html helps for your case.
Also refer http://www.xilinx.com/support/answers/38656.html. Concepts give idea about usage of differential pair signals
01-08-2015 12:44 AM
This is due to incorrect constraints on the clock source.
Compare your constraints with the master constraints file section of below doc and correct them
http://www.xilinx.com/support/documentation/boards_and_kits/zc702_zvik/ug850-zc702-eval-bd.pdf
01-08-2015 12:50 AM
My constraints are correct i checked it
01-08-2015 12:50 AM
if you have used differential input clock,
are you also using IBUFDS/IBUFGDS to convert it to single ended?
thanks,
Shreyas
01-08-2015 12:56 AM - edited 01-08-2015 01:44 AM
Use IBUFGDS instead of IBUFDS.
Refer below link for more details and template related to IBUFGDS:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_1/7series_hdl.pdf
Let us know if you come across any issue.
Anusheel
Helpful answer -> Give Kudos
