TCP client server code for ucos-ii
hi
The example code provided by the micrium for TCP ( server) is working for ucos-iii. But i want to run it in ucos-ii..it is showing UCOS- TCP initialization fail, Error code 20012 ...what is the solution for that.
hi gbishnuprasad@gmail.com,
μC/TCP-IP requires the presence of an RTOS for task scheduling and mutual exclusion. To meet this requirement, Micrium provides source code to allow network applications to readily accommodate μC/OS-II and μC/OS-III.
Download the files from the Micrium web site:
http://micrium.com/downloadcenter/download-results/?searchterm=hmxilinx&supported=true
Sarada
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented.
