mirinchina
Timing Constraints: OFFSET for bi-directional Port (inout)
Hi Members,
I want to improve my UCF by adding timing constraints (OFFSET IN & OFFSET OUT). Actually in my TOP level module there is bi-directional bus. How i can constraints for my data bus type as 'inout' .
- OFFSET IN for input ports
- OFFSET OUT for output ports
* Syntax is cleared
I am confuse how to deal with bi-directional bus.
N. Mir
vemulad
Hi @mirinchina
You need to write both OFFSET IN and OFFSET OUT constraints for bidirectional ports.
Check this AR http://www.xilinx.com/support/answers/36414.html
Deepika.
Deepika.
