saijulukose
UART of zynqzc702 not detected
hy all,
we have a zynq zc702 we are facing an issue that the uart of the board is not detected.what could be the issues.we have tried almost everything mentioned in the start up guide still its not detecting.Can anyone help us out with the same.
htsvn
hi,
please run through the BIST example as documented in this link.
https://www.xilinx.com/support/documentation/boards_and_kits/zc702_zvik/2014_3/xtp180-zc702-bist-c-2014-3.pdf
--hs
pratham
@saijulukose Please let us know what all things you have tried at your end.
1) installed the UART drivers?
2) Tried changing UART cable?
3) Did you ever use this Board's UART successfully?
4) When did you purchase the board? if all debugging is done please contact your distributor and file an RMA if it is under warranty period.
-Pratham
saijulukose
 hy,
1) yepp we have installed the silicon labs driver for UART.
2) tried changing the uart cable
3) yep we were using it sucessfully all of a sudden it stopped working.
4) we have purchased it online through xilinx website.so whom to contact? its over 6 months so RMA cannot be generated.
can u please guide what has do be done next?
saijulukose
@pratham
hy,
