lsc-unicamp
Ultascale+ (zcu102) Ubuntu
Hi, I'm trying to follow and boot Ubuntu from this tutorial onto a Rev1.0 board:
http://www.wiki.xilinx.com/Zynq+UltraScale++MPSoC+Ubuntu+part+2+-+Building+and+Running+the+Ubuntu+Desktop+From+Sources
There is just no success in booting it. I've tried the mode SW6 in either 0x5 and 0xE.
I also tried to generate BOOT.BIN from this manual:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug1144-petalinux-tools-reference-guide.pdf
also no success. The only thing that appears when I connect to ttyUSB0 is the following:
Xilinx Zynq MP First Stage Boot Loader
Release 2016.4 Mar 16 2017 - 17:00:01
I did use the ES2.0 bsp package, and copied all .elf files and .bit to ubuntu folder in order to run bootgen. Is someone having the same problem? Someone tried something different from me?
Thank you in advance!
