thaus_015
Unable to detect this error code in HLS :memory copy is not supported unless used on bus interface possible cause(s): non-static/non-constant local array with initialization)
Trying PRBS in HLS and integrating the HLS IP with XSDK as a Task. In Hls, during synthesis "memory copy is not supported unless used on bus interface possible cause(s): non-static/non-constant local array with initialization" .Please solve my problem.
Using kintex 7 and microblaze, i need to get random bits 0`s and 1`s in a consecutive manner at Tera Terminal through stream communication HLS IP and XSDK. Please suggest me.
Source code as follows
#include <stdio.h>
#include "ap_cint.h"
#define N 50
typedef uint32 DT;
void PRBS_Mem(volatile DT *d, int bit)
    // Define the RTL interfaces
    #pragma HLS interface ap_ctrl_none port=return
    #pragma HLS interface ap_bus port=m
    // Define the pcore interface as an AXI4 master
    #pragma HLS resource core=AXI4M variable=m
     unsigned lfsr  = 0xCD;
       int  i,j;
       DT buff1[N], buff2[50];
       memcpy(buff1, d, N*sizeof(DT));
        for ( i = 0; i < N; i++)
              bit = ((lfsr >> 0) ^ (lfsr >> 2) ^ (lfsr >> 3) ^ (lfsr >> 4) ) & 1;
              buff1[i] = bit; //storing bit value in buff1
              lfsr = (lfsr >> 1) | (bit << 7);
        for (j = 0; j < 50; j++)
        buff2[j] = buff1[N-j] ; // from buff1 storing bit value into buff2 for reading the bits in consecutive ways
        memcpy(d, buff2, N*sizeof(DT));
Tags (2)
muzaffer
@thaus_015 you have no port called "m" (lines 11 & 14) perhaps you meant "d" ?
muzaffer
