l.enoal
Use one regsiter per slice
I use a kintex 7 XC7K70T consist of 8 registers per slice and i would like to know if it's possible to contrain the implement design in ISE to use one regsiter per slice.
Thank you.
anusheel
@l.enoal
Best way is to open the design in PlanAhead and create a Pblock for the targeted module/cells, this will tell the tool to place the logic within the Pblock(area selected in device). In case you don’t want to use PlanAhead for further flow, simply imoprt the PlanAhead generated constraints in ISE.
Regarding FF/Slice related query, you need to write a script which can write LOC/BEL constraint for the desired FFs. This way you can place the FFs in Slices as per your requirement.
Anusheel
Helpful answer -> Give Kudos
syedz
@l.enoal,
Just curious, Why would you wana implement only one regiister per slice?
--Syed
syedz
@l.enoal,
May be you can try with Unique control signals (Clock, CE and SR)  for Each register so that they are placed in different Slice.
Check this AR#24667
http://www.xilinx.com/support/answers/24667.html
--Syed
anusheel
@l.enoal
Yes, you can lock them manually if you are targeting less number of registers.
I guess there is no global switch for this requirement. Also, if the flops are using different control signals then by default tool has to place them in different slices.
Anusheel
l.enoal
Thank you for your answers.
So, if I understand there aren't options into ISE softawre to force the implement design use one register per slice. And with FPGA Editor or Floorplan it isn't possible? Because in my code all regsiters don't use the same control sets.
And also, is it possible to choose the slices that we want use with the tools of ISE. For example if I want just use a part of chip and not all chip.
Best Regards
nagabhar
HI @l.enoal
You can use AREA_GROUP constraints  (pblocks in PLanahead), to constraint a part of your design to a particular region of the device.
refer page 46 of  contraint guide
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/cgd.pdf
Bharath
Please mark the Answer as "Accept as solution" if information provided addresses your query/concern.
anusheel
@l.enoal
Anusheel
