Visitor wywywgy520
Using Partial reconfiguration controller on VC707 ---Base on UG947 Lab3
Hi Friend
UG947 (v2016.2) June 13, 2016 lab3 : Partial Reconfiguration Controller IP
I want to know if somebody has finished  it on VC707.
BR
Re: Using Partial reconfiguration controller on VC707 ---Base on UG947 Lab3
You can try using the same design and then change the device and ensure you have got rid of any errors and also timing constraints are met.
Anirudh
PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution.
BR,
It'll be a little more than just changing the device.  You'll need to update the pinout of course, plus all the bitstream sizes to be computed for the PR Controller itself will be different.  But the design itself does not have to change.
I am updating UG947 for 2016.3 this fall to include not only the VC707 but also the VCU108.  Send me a PM and I can send you the constraint files and IP generation Tcl you'll need to target the VC707 now.
thanks,
david.
