Using Revision stack for Virtex-7 FPGA VC707
I am planning to implement neural networks and computer vision applications on Virtex-7 VC707. I would like to know if I can use Xilinx’s reVISION stack tools like SDSoC Development Environment, and libraries provided by Xilinx for development on virtex-7 VC707.
In the documents related to reVISION stack, I only see the mentioning of zync ultrascale SoC and MPSoC boards. Please clarify if the revision stack tools and libraries are supported for virtex-7 board.
https://www.xilinx.com/support/documentation/backgrounders/revision-overview.pdf
Sridhar Gunnam
s,
The whole idea is to take programs written in c, and port them to accelerators built in logic AND run what's left on processors.
So, no, as the VC707 has no processors, it is not a good fit for the reVision suite.
Could you replace the ARM processors with MicroBlazes, and still use techniques in the reVision suite?  I suppose you could, but that is not what the documents support.
Austin Lesea
Principal Engineer
Xilinx San Jose
