Newbie eprom04
Using a XC9572XL to drive a 2 digit 7 segments lcd display
I was about to use some normal XOR ports to do the job but since I am just starting to
use this CPLD for fun I wonder if I can better use it and possibly add some other features
not present in the very first design. I would like for instance to know if the chip I am using
is capable (beside the XOR combinational logic) to add two 8 bit latches to store the status
of both the 7 segment digits. I think I read also in this forum that t´s possible to change a port
type of a not port to become a schmitt trigger port and thus be usable as rc oscillator for the 30 Hz
clock needed to drive the lcd. Is it true and possible? So basically the questions are two, can I add two
8 bit latches to the circuit? And, can I use a port as schmitt trigger to make a low frequency rc oscillator?
Thank you so much
Francesco
Teacher muzaffer
Re: Using a XC9572XL to drive a 2 digit 7 segments lcd display
Yes to both questions.
Newbie eprom04
Thank you.
