VCU110 QDR memory
I was looking on the VCU110 schematic at the QDR interface and it shows A19 as going to C6 of the QDR ram.
I checked this pin (C6) from 3 ram manufactures and it shows C6 as a NC pin. There is a note on the schematic
which eludes to BL 2 and BL 4 transfers.
 Does anyone have anymore information on this?
Re: VCU110 QDR memory
@kguzzino Believe that C6 pin (A19 address) is additional address pin for Two-Word Burst Length QDR's. For Four-Word Burst Length QDR it is No connect.
You may have checked all 3 RAM manufacturers of Four-Word Burst Length QDR and so see the NC. Try checking a Two-Word Burst Length QDR datasheet and I think C6 should be an address pin.
- Giri
- Giri
Thanks. That's what I needed.
