VHDL 2008
Support for VHDL-2008 in Vivado Synthesis is tentatively expected in the 2014.x release. Support for VHDL-2008 in simulation is expected in 2014.3.
Re: VHDL 2008
Thanks and Regards
Balkrishan
Re: VHDL 2008
Was is the current status for support of VHDL 2008 in simulation? It seems it is still not there as of Vivado 15.2
I like these books:
Free Range VHDL (free), http://www.freerangefactory.org/site/pmwiki.php/Main/Books
VHDL for Logic Synthesis, Andrew Rushton
FPGA Prototyping by VHDL Examples, Pong P Chu
Re: VHDL 2008
Hello @rlewis65,
http://www.xilinx.com/support/answers/62678.html
Ashish
Re: VHDL 2008
I just tried VHDL 2008 in Vivado 2015.4 and made the following observations:
1. The Vivado simulator does not yet support the fixed-point package with datatypes sfixed() and ufixed(). The reading of table E-1 in UG 900 p. 194 seems to be misleading.
2. Vivado synthesis supports those data types but it seems that the VHDL 2008 standard was implemented in a wrong way:
The IEEE VHDL LRM states in rule G 4.3:
"The data widths in the fixed-point package are designed so that there is no possibility of an overflow. This is a departure from the NUMERIC_STD model, which simply throws away underflow and overflow bits."
This implies for the add operator that an additional output bit has to be added (see table G.2) of the LRM.
But when I implemented the following code
library ieee;
use ieee.fixed_pkg.all;
entity FIXED_PACK is
port(A,B : in sfixed(3 downto -3);
     SUM : out sfixed(4 downto -3)
end FIXED_PACK;
architecture ARCH of FIXED_PACK is
begin
  SUM <= A + B;
end ARCH;
i get the following error:
  • [Synth 8-690] width mismatch in assignment; target has 8 bits, source has 7 bits ["../VHDL_2008/VHDL_Codes/fixed_pack.vhd":11]
Could you confirm that this is an error and could you please give as a roadmap which explains the complete implementation of the VHDL 2008 standard for simulation and synthesis which was finally defined already 7 years ago.
with kind regards
Juergen
