piyushashtikar
VLNV <analog.com:user:axi_clkgen:1.0> is not supported for the current part ?
We are working on a custom board with a Zynq on it.
It has a  ADV7511 HDMI transmitter connected to Zynq.
I have built linux u-boot and kernel for displaying the output of zynq on HDMI monitor
for this, I am using a HDL design from this link
https://github.com/analogdevicesinc/hdl/tree/hdl_2016_r2
Now, when i try to load this on Vivado 16.2(as the branch suggests), I encounter error as shown below:
VLNV <analog.com:user:axi_clkgen:1.0> is not supported for the current part.
On the loaded design I do not see a source for clkgen
Any help is highly appreciated.
florentw
Hi @piyushashtikar,
The axi_clkgen IP is in a different folder in the git repository (link). You have first to build the IP and then add it to your IP catalog.
This should be done if you use:
make -C projects/adv7511/zc706
 Hope that helps,
