rakeshgehalot
Virtex 6
Hi everyone
I am working on virtex 6 ML605 Rev D(xc6vlx240-1ff1156) last 4 month.
I don't know what happened to board it is not uploading the bit stream file (.bit file) on board. it is a simple led blink program.
here is the error from impact and xmd both. If you need more info. kindly reply.
Please help.
umamahe
Please check as per below debug checklist to find out board health
https://www.xilinx.com/support/answers/40398.html
umamahe
gnarahar
@rakeshgehalot Check this AR for your ID Code error you receiving
https://www.xilinx.com/support/answers/13529.html
- Giri
There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered.
Keep conversing, give Kudos and Accept Solution when you get one.
rakeshgehalot
Thank you @umamahe @gnarahar
